Upgrades
Old Feb 4, 2013 | 11:18 PM
DevonMolendyk's Avatar
Default Upgrades
Ok so i got a 2001 24valve. It has an Edge Juice with Attitude, 4in staight pipe, and cold air intake. Im trying to find some modifcations i can do for cheap. I NEED IDEAS!!! thank you all for your time
Old Feb 5, 2013 | 09:44 AM
GuyWithA24Valve's Avatar
Do you have an aftermarket lift pump or gauges?? If not you need both of those ASAP. What kind of tranny do you have?
Sent from my iPhone in the cab of a Caterpillar
Old Feb 5, 2013 | 02:12 PM
lauber_03's Avatar
upgrade lp first thing, ejwa has gauges on it already. torque converter and valve body would be a big help too.
Old Feb 5, 2013 | 06:41 PM
It has an automatic trans
Would it be smarter to do the lift pump before injectors? I was looking at 75 horse injectors and im not sure which order to do it in.
Last edited by DevonMolendyk; Feb 5, 2013 at 06:41 PM. Reason: Automerged Doublepost
Old Feb 5, 2013 | 07:25 PM
rrimpa's Avatar
lift pump first, always
Bryce's Avatar
Lift pump first
Old Feb 5, 2013 | 07:32 PM
KillStroker's Avatar
Double down on the Lift pump... What are you getting for Fuel Pressure? If its less then ten your fudged sooner or later and injection pumps are not cheap. I bet your around ten and a whole lot less than that when you put her to the floor on stock LP. Besides how are you gonna feed those new injectors if you dont have good flow of fuel bud... Take our advice do the LP....I think i beat that horse.
Old Feb 5, 2013 | 07:53 PM
chuffysplace's Avatar
Yes..right on. Here's mine. FASS 150 titanium, came with 3/8 line, fittings and mounting bracket.
Attached Thumbnails Upgrades-2012-12-23_11-41-28_621.jpg   Upgrades-2012-12-23_11-41-08_174.jpg
Old Feb 5, 2013 | 08:35 PM
Ok its settled ... now what would be a good brand to go with? I am on a somewhat tight budget, probably around $400, but i want something that will last. Ideas?
Old Feb 5, 2013 | 08:37 PM
Spend a little more an get a DTT Assassin.
Luke
