Need repairs
Old Feb 4, 2013 | 10:24 PM
Dieselboy1992's Avatar
Default Need repairs
Alright I have a 03 6.0 and I blew the high pressure oil pump and need new injectors any tips on what to go with and maybe some pricing
Old Feb 4, 2013 | 11:08 PM
bobfbigman's Avatar
Were the injectors known to be bad before the HPOP failed? For injectors the best to go with are Ford injectors, any injector you get is going to be a rebuilt unit. Ford /alliant/ redisigned the spool valves to eliminate stiction, plus they have the best warranty on them, Think Ford sells them for $230 a piece plus you have to turn in the core.
For the HPOP you can either go with the stock Ford unit,around $560 or you can go with a billet redigned pump that will last a lifetime from DIESEL SITE.com they flow alot better and make it run better but they are $1000
Old Feb 5, 2013 | 06:26 PM
CTC DEEZUL's Avatar
you probably did not 'blow' anything. Just a typical HPOP failure, which does not send any metal into system
and your injectors are probably fine. I see no way of diagnosing injectors if the HPOP has failed....
Old Feb 5, 2013 | 09:57 PM
I just took it in and that was everything they told me was wrong they told me my injectors were weak about two weeks before
Old Feb 5, 2013 | 10:52 PM
bobfbigman's Avatar
If all the injectors are weak/I doubt it/ then it is most likely a weak FICM, might think about sending it out for repair and it will last alot longer then a new one and alot less expensive.
kyletg14
10
Nov 23, 2014 01:06 AM
Nov 20, 2014 08:10 AM
