2.5in spacers
Old Feb 4, 2013 | 07:06 PM
Al31031's Avatar
Default 2.5in spacers
Hey guys quick question on something that im not really knowledgeable in tires and suspension my question to you guys are im running a 2" leveling kit but i wanna know if my 2.5" wheel spacers make any difference in the size of the tire i can run? What i mean is would spacers help out for rubbing or would it make it worse or is it the same idk small story short i wanna run 35's with just a leveling kit and 2.5" spacers will it be okay?
Old Feb 4, 2013 | 07:33 PM
blacksally's Avatar
thats what i run its all about the spacing on the rims i had 35s on 06 stockers and they rubbed the a arms then another buddy didnt rub??? idk but i have some ar mojave 16s with dang near 35s no problems
Old Feb 4, 2013 | 07:47 PM
Al31031's Avatar
so your saying ill be fine with the spacers and the 35's though? because it just seems like i cant get a straight answer off any site or wherever
ow and btw idk if this matters but is a sport so it does have a sport front bumper you think it will matter?
Old Feb 4, 2013 | 11:34 PM
DevonMolendyk's Avatar
you will be fine with a leveling kit with out the spacers. you would rub on the control arms a little but nothing to worry about. the spacers will stop the rubbing on the control arm but they will push the wheels way outside the fenders. if you got wheels with a little more of an offset, i have -6 offset with 35's and no rubbing, you would get the best of both worlds.
Old Feb 5, 2013 | 07:54 PM
Al31031's Avatar
thank you i just dont want any rub at all thanks alot!!!
Old Feb 7, 2013 | 01:11 PM
vcustoms86's Avatar
I run 315's with a 2in leveling spacer. Dont rub at full lock either direction.
Old Feb 9, 2013 | 07:05 PM
toughtoy4x4's Avatar
One other thing to consider...if you choose to run those 2.5" spacers, be prepared to replace those front unit bearings at $400.00 a piece some time in the near future. I'm assuming you have a 4x4. You'll also want to make sure your rear bearings are well packed and tight. If they're even a little loose, the extra stress of moving the tire/wheel out will eventually cause early failure.
Old Feb 10, 2013 | 08:32 AM
Al31031's Avatar
ya i actually just put new bearings in
cummins.1.5.3.6.2.4
Sep 20, 2015 01:47 AM
