Trans Upgrade?
Old Mar 24, 2008 | 09:05 PM
dalton06's Avatar
Default Trans Upgrade?
I was just wondering what yall thought about trans upgrades. I'm not going hardcore with power. Right now I'm at 423/824 without crazy larry or stacked with quadzilla. It slips a bit when I really play. I really don't want to sink thousands into a full billit tranny that I will never really use its potential. What would yall suggest for a mid power safe trans upgrade? Torque converter and shift kit? Thanks for the info, I just want to play safe
Old Mar 24, 2008 | 09:26 PM
Suncoast VB and a Triple Disc Converter
Old Mar 25, 2008 | 12:49 AM
dalton06's Avatar
since I don't plan to do much hardcore stuff do yall agree that I shouldn't go all out in the tranny. Even now I mostly ride around in stock settings anyway.
Old Mar 25, 2008 | 11:06 AM
Go with a good Converter and VB then down the road get a good rebuild.
Old Mar 26, 2008 | 12:16 PM
06MegaCab's Avatar
i have a similar problem mine is slipping so im going to get it rebuilt and then add a VB, Torque Converter, and a new flexplate, will a new imput shaft be required?
Old Mar 26, 2008 | 03:24 PM
It is not required but it is recommended
Old Mar 26, 2008 | 05:11 PM
greasemonkey's Avatar
you should definitely upgrade the converter, it makes a very significant difference. both of my brothers are running Dave Goerand's converter/valvebody. The parts and customer service are flat out amazing. One is a relatively stock truck (air box, exhaust, Bullydog) that's commuted, the other is a 13+ second 1/4 truck that's also commuted. even on the nearly stock truck, the converter may be the best upgrade you can do!
converter and flexplate are a must. I've seen countless flexplates with the holes ripped out from stock power 3rd gens. if you do a valve body upgrade, which you should just to do it right and be done with it, the band apply lever/anchor is a highly recommended upgrade, as the stock apply levers don't do well with the added pressure.
so call up Suncoast and Dave Goerand, tell them what you do with your truck and be realistic with your future power/use plans.
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
Dudeman
Apr 5, 2015 10:28 PM
D-350 dually
9
Feb 11, 2015 12:37 AM
Pyrohigh
Oct 11, 2014 07:59 AM
