Transmission help
Old Feb 3, 2013 | 09:06 PM
akacroftie's Avatar
Default Transmission help
The other day I was leaving the house and got into the skinny pedal pretty good, hit the rev limiter and then the transmission started shifting funny. It was like it wouldn't shift out of 2nd gear. Now a few days later it seems fine once I get up to running speeds but every now and again it will take off in second gear. I have a quad adren on it, air dog fuel system, and a 5 inch turbo back on it. It looks like the second gear band has been adjusted pretty far out. Also when I pull it into reverse it use to shift where you could feel it and start to go now its like it has no power until you give it a little gas, same thing happens in drive as well. Someone help!!!
Old Feb 3, 2013 | 09:22 PM
GuyWithA24Valve's Avatar
Well I would adjust the bands first. What does your tranny fluid look like? If you have those power adders with a stock transmission, then you're probably going to have to look at upgrading your transmission. They weren't built to handle anymore power than stock
Sent from my iPhone in the cab of a Caterpillar
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
