radiators and upper hose cold
Old Feb 3, 2013 | 04:58 PM
smedley's Avatar
Default radiators and upper hose cold
what would cause my radiator and upper hose to stay cold? the upper hose is hard so it has pressure. temp gauge reads 190deg too. it is around 20deg here.
Old Feb 3, 2013 | 05:06 PM
Red_Rattler's Avatar
High Tech Redneck
Rad and overflow full? Truck has good heat? When it's that cold the truck really doesn't have to flow that much coolant to stay at operating temp unless you are working the **** out of it or have the grill blocked off so the truck makes heat
Old Feb 3, 2013 | 05:19 PM
smedley's Avatar
it has good heat when it gets warmed up which takes awhile. overflow and radiator is full.
