need help on 01 cummins
Old Feb 2, 2013 | 02:25 AM
Rienas's Avatar
Default need help on 01 cummins
it was running fine than it lost all power i was lucky going 5mph than i parked and shut her off than when i tried to start it agian it wont start and the wait to start light wont even come on any ideas
Old Feb 2, 2013 | 11:55 AM
Bryce's Avatar
First thing to do is check for codes. You can do the key trick (off, on, off, on, off, on leave on and codes will show in the odometer) but it is better to use a scanner. If you don't have a scanner or know anyone that does you can rent one from O'Reilly's and many other parts stores.
Old Feb 2, 2013 | 12:13 PM
Rienas's Avatar
on way to napa im going to get a scanner and fuel filter also
Old Feb 2, 2013 | 12:28 PM
Bryce's Avatar
Napa filters are ok to get you by but they are not the best choice for your truck. Do some research on both fuel and oil filters because some of them are not approved for use on cummins. I would recommend Fleetguard or Baldwin for fuel filter and Fleetguard stratapore or Donaldson ELF for oil. I use Baldwin and from my local Peterbuilt store they are quite a bit cheaper than getting one from an auto parts store.
Old Feb 2, 2013 | 04:39 PM
Rienas's Avatar
alright i apperciate it but im getting somthing that will get me bye because im broke down 4 hours from my house so it sucks
put new fuel filter in and scanner will not read my code but i sprayed a lil ether in the turbo and still wont start and my wait to start like nor my fuel gauge is working any ideas
Old Feb 2, 2013 | 05:00 PM
Bryce's Avatar
If you bump your starter can you hear the lift pump running?
Is the truck stock or do you have a chip or any other mods?
Old Feb 2, 2013 | 08:26 PM
Rienas's Avatar
i have an edge comp box and a raptor 150 lift pump
Old Feb 2, 2013 | 09:28 PM
rrimpa's Avatar
you might want to start by checking your fuses and relays, sounds like you have an electrical issue
Old Feb 3, 2013 | 01:31 AM
Rienas's Avatar
all fuses check out is their any other relays besides under hood and on side of dash by drivers door
Old Feb 3, 2013 | 04:24 AM
Sounds like your Computer took a dump.
Luke
