edge cts settings
Old Jan 29, 2013 | 09:30 PM
caddo's Avatar
Default edge cts settings
i have a stock 2004 f 250 6.0 only a egr delete done 140,000 mile and nine years of service and still going strong just installed a edge cts and i would like to know what would normal reads be. like the max eot or boost or others what would you monitor or set your alarms at also i am pulling a 36 foot trailer at 11000 pounds sometimes thanks for your help this site has been a ton of help thanks to all for the imfo everyone gives.
Old Jan 30, 2013 | 08:19 AM
Mdub707's Avatar
No other mods on the truck?
The truck will basically protect itself from real emergency situations, if EOT gets too hot it will actually cut fuel on it's own, ask me how I know.
I would keep an eye on EOT and ECT together though, the temp differences is what's important here, more so than an overall temp of each. They should never really spread more than 15* apart. If they do, it's likely your oil cooler is clogging and needs rebuilding/replacing. Clogged oil coolers are usually what cause the blown EGR coolers and blown headgaskets, believe it or not. There really isn't a "max boost" but most normal trucks will run around 22-24 unloaded and you might see as high as 30 with that much weight behind it. No worries there, my poor stocker has maxed my 35psi gauge a few times.
What else is done to the truck? A coolant filter would be a good idea to keep that oil cooler clean and is relatively inexpensive.
Old Jan 30, 2013 | 08:43 AM
caddo's Avatar
thanks for reply will install coolant filter soon and pull rad and get my brother to pull rad top tank off and rod out i used to own a radiator repair shop for 30 years got out of it 5 years ago i have rodded out a ton of radiators with that brown sludg and fine core sand. most radiator core fins do not catch it most of the time but never think a flush will unclog a radiator i know that it will clog coolers though i will do radiator because its free only problem i have had with truck is sticking egr valve.
Old Jan 30, 2013 | 08:48 AM
Mdub707's Avatar
You could always just delete the entire EGR system, greatly increase reliability. Can be done for under $200 now.
Old Jan 30, 2013 | 08:56 AM
caddo's Avatar
did egr delete kit did not replace oil cooler i hope that does not come back and bite me had tuner on it remover it i just want reliable truck worked on cars to long will not do it any more i will sell truck before doing a lot of work had truck new and had 7.3 before that.
Old Jan 30, 2013 | 09:58 AM
Mdub707's Avatar
Oil cooler really isn't terribly hard to do, and less than $300 in parts. It's certainly easier and WAY less expensive than headgaskets.
Old Jan 30, 2013 | 10:02 AM
caddo's Avatar
do you see alot of oil coolers go bad what is the odds you think.
Old Jan 30, 2013 | 10:35 AM
Mdub707's Avatar
More like "when" it goes bad, not "if." Keep an eye on it. The coolant filter will greatly reduce the risk of it having issues. The EOT and ECT should tell you exactly how it's doing. You're already off to a much better start than most. Probably 90% of 6.0 owners don't even know to keep an eye on it, and even some of the ones that do, still don't.
It wont happen overnight, but they slowly build up debris and clog. Two thoughts to this, one is the silicate falls out of suspension in the coolant that Ford uses, so you'll see a lot of guys recommend changing it out for some sort of ELC coolant, CAT coolant being the most popular and Rotella has one too. Few choices there. I'm not sold on that one, and will be using Ford Gold again when my new oil cooler goes in mine next weekend or so. (I keep saying this every week ). The other thought is the block material itself is made by a process known as sand casting. Over time some of the sand particulates break off in the coolant system and clog the oil cooler. There's a few different ways to point the finger here, but really all that matters is you're aware of it and to keep an eye on it. There are fixes, but what you're doing is good enough. If you're feeling saucy, BPD (bulletproof diesel) sells an external oil cooler, that completely alleviates this issue, but it's almost $2k. Stock OEM oil cooler rebuild kit with new core is like $275...
Old Jan 30, 2013 | 12:02 PM
caddo's Avatar
i looked at doing oil cooler and should have done it when i had it down but did not stupid me but now i can watch ect eot it is running about 15 to 16 dif what would be a dif that would make you do a new cooler
Old Feb 1, 2013 | 11:49 PM
azflyman's Avatar
Everyone here told me 15 degrees is the cutoff for installing a new cooler. That is no load going down a flat road. If you are at 15 degrees difference, driving 60, on a flat road, its probably time for a new oil cooler.
David4684
Aug 10, 2015 03:59 AM
Dr67
Apr 30, 2015 12:36 PM
Bowling_77
Feb 22, 2015 10:58 AM
somarillw
Dec 8, 2014 09:07 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
