how to diagnose a bad fuel shut off solinoid?
Old Jan 29, 2013 | 01:18 PM
78fordf150ranger's Avatar
Default how to diagnose a bad fuel shut off solinoid?
Okay I was have some issues a few months ago with my FSS and have purchased a new one ,bit before I install it I would like to know what the 2 wires do and how I go about testing them to make sure everything is good.
Old Jan 29, 2013 | 02:31 PM
RAW's Avatar
RAW
Apply power and ground to the two wires, and see if the linkage moves in. Make sure it pushes/pull hard, you should have a hard time fighting it.
Old Jan 30, 2013 | 03:29 PM
db Zac's Avatar
1st Gen shut offs don't move any linkage. The best way to check it would be to start the truck, then disconnect the two wires that connect to it. If the truck doesn't shut off, the solenoid is your issue. Remove the solenoid and fish the plunger ans spring out of the pump. Inspect the plunger tip for rips or chips. If it has a rip or chip, there's the problem
Old Jan 30, 2013 | 03:49 PM
RAW's Avatar
RAW
Oops, I was thinking P-Pump style.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
Mike H
Jan 25, 2015 10:08 AM
