Nv4500 not working
Old Jan 28, 2013 | 07:22 PM
scottywiest's Avatar
Default Nv4500 not working
My buddy has a nv4500 with a 500hp cummins, he was towing a gooseneck not sure of weight but uphill and the transmission just stopped! I don't kno if it went click clank or boom, what could be the problem it's only got 5k miles on it, also I have a chance to buy that transmission with a triple disk clutch and all the parts to change my auto to manual, he only wants 800 for all of it due to him purchasing an ats stage 6 rebuild for his auto!!! I'm just curious as to if its worth it and if I could rebuild it for myself, i dont tow a whole lot, just a 16' tandem axle toyhauler prolly 8k and i live in the mountains in va, thanks in advance for any input!
Old Jan 28, 2013 | 08:20 PM
jake74's Avatar
If it won't do anything when you put it in gear it probably broke the input shaft.
Old Jan 28, 2013 | 08:24 PM
BarryB's Avatar
With out knowing more details, it could be anything. broke input shaft. fifth gear nut backed off.
These transmissions aren't that bad to rebuild. but you have to have patients. I bought my last replacement gears and rebuild parts from anaheim gear. they were good to deal with and parts were fairly inexpensive.
Old Jan 29, 2013 | 05:17 AM
If it broke the input would that mess the clutch pressure plate or flywheel???
Old Jan 29, 2013 | 06:41 PM
BarryB's Avatar
Again without knowing more of the details. Its a guessing game. The clutch could've broke. highly unlikely, but anythings possible. If it jus broke the input shaft and not the gears. Thats a simple fix. replace the input shaft clean it out real good, metal shaving and etc.
Old Jan 29, 2013 | 07:00 PM
I won't know anything till the rest of his ats kit comes, I'm just curious as to if its worth buying or not because I'm tired of throwing money in my auto and besides I like choosing my own gears
Old Jan 30, 2013 | 04:10 PM
BarryB's Avatar
As long as as its not busted real bad. I'd say its worth it. especially if you can do the work yourself.
Old Jan 31, 2013 | 12:22 AM
RollinCoal99's Avatar
$800 for a nv4500 with a triple disc defiantly worth it, its not that expensive to rebuild
Old Feb 3, 2013 | 06:07 AM
Ok here's an update, he went to pull the truck in the garage to pull the nv4500, will not move, started truck pushed clutch and tried to put in 1st gear easily, grinding sound,soo tried 2nd same sound, soo what is wrong with it, input broke? Output?
Old Feb 3, 2013 | 10:46 AM
chadcycle 2500's Avatar
pull top cver off!!
