Rough idle rough ride
Old Jan 28, 2013 | 05:36 PM
Diesel firefighter's Avatar
Default Rough idle rough ride
Ok guys my truck is an 05 no mods jus exhaust had the heads done a few months back. Couple days ago truck started idling rough an running rough no codes were found had it read twice now I'm stumped so any help is appreciated
Old Jan 29, 2013 | 09:15 AM
Mdub707's Avatar
Need to get it hooked up on a good scanner, like AE with enhanced Ford bundle, or find someone with Ford's IDS.
Without knowing anything else... I'd start with the basics, check the battery life, check the FICM, ideally monitoring ICP actual and ICP desired would be good. Then an injector buzz test and cylinder contribution test.
Where are you located again? I've probably asked, but can't remember. It helps to have your location in your info on the right so I can point you to a good shop near you.
Old Jan 29, 2013 | 03:37 PM
Huntsville texas
Old Jan 30, 2013 | 07:36 AM
Mdub707's Avatar
You're only about an hour away from one of the best powerstroke shops out there you know... Welcome to Power Stroke Enginuities
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
Jan 21, 2015 10:47 AM
Snoobly
Dec 11, 2014 11:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
