CODE 78
Old Jan 28, 2013 | 01:03 PM
Telfair's Avatar
Default CODE 78
I get code 78 often. 1995 Chevy 6.5 diesel. Help Please email me.
Old Jan 28, 2013 | 11:13 PM
racer55's Avatar
DTC 78 -Turbo Wastegate Solenoid Fault
fairly straight forward-replace the wastegate solenoid(mounted on the drivers side valve cover with the vac lines coming from the vac pump to the turbo waste gate).
sometimes some wd40 in the vac ports will do the trick-most times replacement is needed.
also check the wiring to the solenoid for bad connections or breaks.
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
