Boost elbow
Old Jan 26, 2013 | 10:16 AM
codyawise's Avatar
Default Boost elbow
What kind of boost elbows do you guys recommend and will it make a difference?
Old Jan 26, 2013 | 10:24 AM
We use the ones from TST.
Luke
Old Jan 26, 2013 | 07:27 PM
codyawise's Avatar
What's best adjustment? All way turned in or all way turned out?
Old Jan 26, 2013 | 07:42 PM
Al31031's Avatar
it depends on what you wanna run for boost 21 lbs 45lbs kinda test and tune deal all the way in the waste gate will never open and all the way out you will build low boost adjust to what you wanna run. "The elbow just restricts flow going to the wastegate actuator. Restricting this flow fools the wastegate into seeing less boost than the turbo is actually creating. Stock turbo is wastegated at around 20ish psi, in return, the stock turbo will not create more than 20ish psi. If you add an adjustable boost elbow, you will be able to restrict that 20ish psi going to the wastegate down to lets say 10 psi. Since the wastegate is seeing only 10psi (and being as it is set at 21psi) you still have another 10psi that you can build through the turbo (giving you lets say 30) before the wastegate opens".
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
somarillw
Dec 4, 2014 12:37 AM
joshkhouse80
Nov 21, 2014 01:17 AM
