Fue Injection Timing code
Old Jan 26, 2013 | 09:38 AM
danielbrooks89's Avatar
Default Fue Injection Timing code
The other day I was driving my truck it shifted into overdrive and started bogging down. It wasn't bad at first but progressively got worse. The code the truck is throwing when checked is P1963. I had a friend run diagnostics on it and its throwing a fuel injection timing code. Someone give me some idea of where to start trouble shooting. Btw the injection pump was replaced last february where do I need to start????
Old Jan 26, 2013 | 09:50 AM
mysterync's Avatar
Check fuel pressure for starters, sounds like its time for another injection pump.
Old Jan 26, 2013 | 09:56 AM
Thanks that's what I was thinking and the code is not p1963 it's P1693
Old Jan 26, 2013 | 10:12 AM
mysterync's Avatar
Thats just an indicator of a ecm code being present. Theres most likely another code associated with a pump timing failure.
Old Jan 26, 2013 | 10:42 AM
blacksally's Avatar
i had a code like that and it was the fuel filter plugged!!! and it ran good then bad good bad etc check ur filter
Old Jan 26, 2013 | 03:55 PM
I'll check it, but the filter is only a few months old never know though
dwmeehan
Sep 6, 2015 04:20 PM
quiksilver1j
Jul 30, 2015 12:41 PM
flash7210
Jul 5, 2015 09:25 AM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
