Looking for more power
Old Jan 23, 2013 | 04:57 PM
3406_CAT's Avatar
Default Looking for more power
1999 3500 24 valve has AFE cold air, 4" turbo back, EZEDGE chip, and gauges on pillar, looking to add more power, was looking into a Smarty any other things I could do to see more power?
Old Jan 23, 2013 | 05:20 PM
shellinger's Avatar
smarty is really good, i have it stacked with my adrenaline now. love it. cool thing about the smarty is you can read codes, adjust speedo for different tire sizes, and 3 cylinder high idle when its freezing out. we actually put the smarty on my buddys 02 stock automatic cummins a few hours ago just to see what the smarty did for a stock truck and it really woke it up. i would say the smarty is more reliable when it come to programmers because it programs your ecu instead of fooling all your sensors like the adrenaline or edge boxes do. im not sure if you can stack the smarty with your edge ez.
Old Jan 23, 2013 | 05:38 PM
H.R.D's Avatar
Smarty is going to give you the same amout of power as your Edge Ez does. On a VP powered truck you have to tap the pump wire to gain more then 65hp over stock. Modules like Edge J/A, Edge Comp, TST, or something like the Quad Adrenaline do this, the smarty does not. As of very recent, my understanding is Quad has closed up shop due to the EPA's rampage on diesel performance parts and parts makers. So if you want a Quad you better get one fast before stock runs out.
Old Jan 23, 2013 | 08:00 PM
shellinger's Avatar
i have heard the same things about quadzilla. so that being said i would not go with quadzilla. both the edge and the quad have their problems. i believe a resistor on the fuel circuit overheats and causes fueling problems. and if they are closing up shop i would go with the edge then so you can get parts in the future and a warranty.
Old Jan 23, 2013 | 09:01 PM
3406_CAT's Avatar
I guess I can mention it is a five speed manual, has FAAS fuel system installed by previous owner, I also would like to know if stacking the smarty and juice with attitude would work well, and how stacking works?
Old Jan 23, 2013 | 09:35 PM
H.R.D's Avatar
Yes you can stack a smarty with an edge J/A or comp. If you do so you must run the smarty in even numbers that don't increase timing. People have reported a gain with the stack and others have actually reported a loss in HP with the stack.
Old Jan 23, 2013 | 09:37 PM
dieseldude848's Avatar
so if you were to stack the smarty on the ez, it would still be 65hp gain? seems like it would double it
Old Jan 24, 2013 | 01:28 AM
H.R.D's Avatar
Not it doesn't work that way. Total hp gain over stock is right around 65hp without tapping the pump wire.
Old Jan 24, 2013 | 07:10 AM
3406_CAT's Avatar
Okay then how would you take the pump wire then?
Old Jan 24, 2013 | 01:15 PM
H.R.D's Avatar
Only the certain modules that I listed above will do that. The Ez and Smarty don't have the ability to tap the pump wire. That is why you need to get a module that does or the most you can get is 65hp over stock.
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
