CP3 Is Leaking
Old Mar 23, 2008 | 06:47 PM
wildbill's Avatar
Default CP3 Is Leaking
So I suppose the only remedy is to replace the entire unit. Or is there another way?
Old Mar 23, 2008 | 06:57 PM
DangerousDuramax's Avatar
Where's the leak, or is it just bleeding down and not holding pressure?
Old Mar 23, 2008 | 07:02 PM
wildbill's Avatar
I was underneath and found a wiring harness and the underside of the CP3 damp w/ fuel. Lucky it hasn't made it into the oil, or at least I don't think it has. Oil level stays the same.
Old Mar 23, 2008 | 07:09 PM
So its leaking where the wiring harness comes out of the pump? That's actually pretty minor and there should be a replacement seal available. There is no high pressure at that location so some small leakage really isn't much of a problem. I'm willing to bet that most of em leak there a little.
Old Mar 23, 2008 | 07:19 PM
wildbill's Avatar
Kinda hard to tell. Looked over the top and looked a little damp there also.
Old Mar 23, 2008 | 07:21 PM
mysterync's Avatar
this is probably your hard start issue all together!
Old Mar 23, 2008 | 07:22 PM
Hell I just saw this thread and thought the same thing
Old Mar 23, 2008 | 07:40 PM
Yep, you're sucking air. Maybe one of our nice vendors will check on a seal kit available. And don't freak out over doing an overhaul. Its not a difficult as you might think.
Old Mar 23, 2008 | 07:52 PM
wildbill's Avatar
I hope I'm not causing damage. Might be why it's not idling as smooth. Maybe.
Old Mar 23, 2008 | 07:55 PM
mysterync's Avatar
Yup thats your rough idle and hard start! no , Your not causing any damage!
I'll round you up some part prices tommorow!
