shortbed cummins swap in progress!
Old Jan 22, 2013 | 08:58 PM
89&92cummins's Avatar
Default shortbed cummins swap in progress!
i bought an 85 w150 with a 318 auto that run excellent, with a near perfect body, and then there is the old 92 that has been to hell and back, more than once! it is a five speed, I was wanting to fix it up but by the time I fixed the body and rust I would've had 5 grand in it. so I bought a shortbed and tore them both down.
Attached Thumbnails shortbed cummins swap in progress!-img_3025.jpg   shortbed cummins swap in progress!-img_3032.jpg   shortbed cummins swap in progress!-img_3059.jpg   shortbed cummins swap in progress!-img_2769.jpg   shortbed cummins swap in progress!-img_3112.jpg
shortbed cummins swap in progress!-img_3133.jpg   shortbed cummins swap in progress!-img_3144.jpg   shortbed cummins swap in progress!-img_3150.jpg
Old Jan 22, 2013 | 09:08 PM
1993firstgennewbie's Avatar
Are the frames basically the same style or is the 250 bigger and stronger. I always wanted to do a ram charger swap
Old Jan 22, 2013 | 09:24 PM
actually I believe where the shortbed is older, its alittle thicker!
Old Jan 22, 2013 | 09:31 PM
So it should just bolt right in
What are your plans? Dually, srw, 5 speed, auto, lifted, paint, mods
Last edited by 1993firstgennewbie; Jan 22, 2013 at 09:31 PM. Reason: Automerged Doublepost
Old Jan 22, 2013 | 09:39 PM
yep the front crossmember is the same and so is the motor mount holes, I just have to cut a hole for the shifter and have the drive shaft cut down
Old Jan 23, 2013 | 10:45 AM
dewbop's Avatar
nice build man, keep up the good work.
Old Jan 30, 2013 | 07:21 PM
I haven't had a lot of time to work on it lately, and its been pretty cold, but we got the 5 lug front end out and about to switch the 8 lug. also got the fuel tanks switched.
Old Feb 10, 2013 | 09:10 PM
got the front end bolted in and decided to go on and drop the motor and tranny in. it wasn't as hard as I thought it was going to be. the motor mounts fit perfect, but when we went to bolt up the transmition crossmember, the bolt holes wont line up. only a minor setback! the old red and white truck is nothing but a hull now! we should have it running by this weekend.
Attached Thumbnails shortbed cummins swap in progress!-img_3287.jpg   shortbed cummins swap in progress!-img_3285.jpg   shortbed cummins swap in progress!-img_3253.jpg   shortbed cummins swap in progress!-img_3252.jpg
DieselDan370
Diesel Engine Conversions
Aug 23, 2016 02:24 PM
STDiesel59
Jul 11, 2015 10:09 AM
mcclusk
Feb 21, 2015 09:50 PM
Andy81
Jan 28, 2015 02:53 PM
Ryans71
Nov 28, 2014 09:46 PM
