timing & cold start & block heater
Old Jan 22, 2013 | 11:15 AM
artieb's Avatar
Default timing & cold start & block heater
Hi, I have my 1992 VE pump advanced pretty high, starts real well until 20* or so. With no KSB advance. Any colder it starts very hard, with or without the KSB advance. I'm currantly not using my manifold pre-heat, I believe the pre heats just make the engine idle smoothly? The question is if my pump is timed too far, will that cause a cold start issue? Also, my block heater does not work and looking a Zerostart 350-0030? Is this the best deal? Artie
Old Jan 22, 2013 | 12:04 PM
blackduck's Avatar
Remember diesels fire by the heat of compression. Cold air hard to fire, hot air (heaters) easier to fire. Try hooking your pre heat up and see what happens
Old Jan 23, 2013 | 08:24 AM
artieb's Avatar
The CTD is in a 01 Fummins, and would need to build a circut with a solenoid, which would be fine, if that will help? I always thought the block and head tempature was the biggest factor? Someone correct me. I did leave the grid heater, just in case. How long is a safe time to manually leave the Grid heater on? Would NOT want to melt one down. Thanks, Artie
Old Jan 23, 2013 | 09:50 AM
blackduck's Avatar
Scroll down the threads in this list to Grid heater troubles.
You could use the temp switch to run a relay/solenoid or just run the relay with a push button switch as in the other thread.
Old Jan 25, 2013 | 12:00 AM
Screamin' Metal's Avatar
As blackduck said....you want to heat the air, not try and burn the heater out. On my trucks, I have a pushbutton wired to my heaters, 5 to 8 seconds is all thats needed. But like in a ice storm, I might hit it twice. Do what you want, but that block heater will keep alot of undue engine wear down, not to mention faster, smoother starts....
Mike0885
May 27, 2015 12:07 PM
ronstop
Feb 26, 2015 09:48 AM
ramrunner01
Feb 25, 2015 11:14 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
custom7.3
Nov 23, 2014 10:44 PM
