grounding pmd
Old Jan 21, 2013 | 09:23 PM
delinquent33's Avatar
Default grounding pmd
Hello all!
Am installing a PMD relocation kit to inside of front bumper, can i ground the heat sink to the body or do i have to ground to the IP? New to this site, Lots of great info! Thanks for your time.
Old Jan 21, 2013 | 09:37 PM
camaro075's Avatar
I would think u could ground it to ur front bumper cuz its to ground the pmd and the wires to the pmd...so id say yes u could
Old Jan 21, 2013 | 09:55 PM
The extension harness i have is just a plug and play, no wires to ground? The heat shrink has a threaded screw hole. Is that sufficient to ground or do i have to splice into the harness?
Old Jan 21, 2013 | 10:03 PM
camaro075's Avatar
U shouldnt have to grond the heat sink the harness is grounded to the IP and u plug in the extension to the connecter and the apmd is grounded...u dont need to ground the heat sink..
there should be 4 drilled holes to mount the pmd to heat sink and there should be another hole drilled to mount it...
no need to ground heat sink
Old Jan 21, 2013 | 10:16 PM
I noticed when the previous owner relocated the pmd ( to a heat sink above thr exh manifold) he spliced into harness and grounded to engine. If i dont have to do that all the better! Thanks for the info! P.S. I do plan on pulling his harness and goin with the new one right from the IP.
Old Jan 22, 2013 | 03:48 PM
racer55's Avatar
The IP harness ground needs to be grounded to the IP and/or the drivers side battery ONLY.
The PMD heatsink does not require any ground at all but there is no harm in adding 1 and some manufactures even recommend it.
Pictures 2 and 4 of this link show the proper location of the IP harness ground(black wire):
http://www.mamut.net/royh/newsdet9.htm
Old Jan 22, 2013 | 07:34 PM
That makes a little more sense. Much appreciated.
Joracing3
Sep 10, 2016 05:28 PM
98suburbandiesel6.5l
Jul 25, 2015 03:25 PM
petew
Jul 2, 2015 05:40 PM
LTreis702
Nov 7, 2014 08:06 PM
jrsavoie
Oct 8, 2014 06:58 AM
