changing my ijector pump
Old Jan 21, 2013 | 07:40 PM
bigbear109's Avatar
Default changing my ijector pump
iam changing my injector pump and need to know if i need to set the motor timing and the pump timing? or can i set just my ip timing? and get away with it???????
Old Jan 22, 2013 | 06:46 AM
autostroker's Avatar
turn the motor to cylinder 1 TDC compression stroke, line up the timing markes on the gears when you put the pump on. May have to time the pump a little bit, but make sure the static timing is right before you even think about cranking the engine over.
2gCummins
May 25, 2015 02:55 AM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Ironmanqb
Apr 4, 2015 10:27 PM
