6.0 wont start in cold
Old Jan 21, 2013 | 04:46 PM
JoeJP's Avatar
Question 6.0 wont start in cold
I have a 2004 f-350 with 90k. It use to fire up in the cold mornings fine but now it chugs. We installed an EGR delete, with no change except for it chugging black some instead of white. Also put in brand new glow plugs and Glow plug harness and Glow plug control module. Also, just recently, firing it up kills the battery after 2 or 3 tries.
When its cold (only about 40 degrees) it does't want to fire the cylinders and when it does it chugs something fierce until it dies after about 7 or 8 chugs. If it fires up it has no power for the first 7 mins or so.
If plugged in all night it will fire and only chug once or twice. Runs like a top when warm.
Any ideas?
Old Jan 21, 2013 | 04:55 PM
ArcticFlyer's Avatar
Thats the same issue I am having right now, the truck just puked a couple (9) codes, all of them dealing with injector circuit low (all 8 cylinders) and a P0611, that one deals with the FICM. I am taking mine in to have checked and I'll let ya know if the stuff I get done fixes the problem.
Old Jan 21, 2013 | 05:05 PM
JoeJP's Avatar
Thanks. I'm afraid we don't have the same problem because (I forgot to mention in my first post) I don't have any codes and I got a new FICM. but best of luck man. but if the work fixes it please let me know. As my computer my just be on the fritz.
Old Jan 22, 2013 | 12:22 PM
Mdub707's Avatar
A new FICM is not a cure, it just pro-longs the time until FICM failure again. They haven't changed the design at all, so it will keep failing.
Get your batteries load tested individually first JoeJP. It's amazing how poor these trucks run on weak batteries. If one is bad, replace both. Test them and let us know what you find. If they check out, I would test the FICM anyways, test procedure is found at the top of the 6.0 page.
Cavnar
Sep 9, 2015 07:18 PM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
dandbmcc
Mar 14, 2015 11:05 PM
custom7.3
Nov 23, 2014 10:44 PM
