stock filter housing question
Old Jan 21, 2013 | 10:49 AM
grizzzly17's Avatar
Default stock filter housing question
i want to remove my stock filter housing and was wondering if the two plugs that connect to the filter, if i dissconnect them will it throw codes or screw with my ecm and all that? i think ones a heater and the other one is a pressure sensor?
Old Jan 22, 2013 | 08:32 AM
Ed ke6bnl's Avatar
I removed mine and no codes to put in an air dog. I also removed the pump and put in a aluminum plate so I could reuse the same bolts in the intake to take up the space of the pump mount.
Old Jan 22, 2013 | 09:00 AM
colinheitshusen's Avatar
Youll want to keep your heater. anything below -10 and mine liked to freeze up without the heater. Just run your air dog Fuel line to the back of your filter houseing and than back out, than to the Pump.
Old Jan 22, 2013 | 05:41 PM
grizzzly17's Avatar
ok cool, ya i was wonderin about the heater cause its cold here, bout 0 or below in the mornins, but my airdog is hosed directly to the vp44 and skips the stock filter. does the heater work like the block heater that connects to a wall outlet? or like the glow plugs when the key is in the run position? thanks
Old Jan 22, 2013 | 06:17 PM
RAW's Avatar
RAW
The fuel heater uses 12 volt power form the truck. I believe the ECM measures fuel temperature to determine if the heater is energizer or not.
Old Jan 22, 2013 | 07:11 PM
grizzzly17's Avatar
ohh ok, does the heater make a big difference with starting in the cold? also would it be to much resistance on the air dog to have 3 filters inline? doubt it would be but just curious.
Old Jan 22, 2013 | 08:22 PM
MBFD 592's Avatar
when I installed my air dog I left the stock filter in place for the heater, and the water in fuel light. no problems so far.
Old Jan 22, 2013 | 08:32 PM
No the air dog wont have a problem pushing fuel past the original filter. you can leave it empty anyways. starting isnt the issue, its when its running is when you get problems cause its not running by a heat source at all. And like RAW said the fuel heater only works when needed
Old Jan 22, 2013 | 08:40 PM
North Maine's Avatar
Not only starting, but to STAY running as well. My FASS is plumbed to feed the stock filter so fuel can continue to be heated when needed. Even with that, today at -10 I was freezing my FASS filters up and the truck was stalling out at anything over low-rpm idle. Once the truck had idled for 30-40 minutes (and a healthy dose of DIESEL 911) I was able to hit the road without bucking, smoking, and stalling.
jeffersonl
Nov 15, 2015 07:35 PM
wannadrag
May 25, 2015 03:07 PM
Bob V
Apr 6, 2015 11:02 PM
roanokerivermud
Dec 4, 2014 10:52 AM
jeffersonl
Oct 25, 2014 06:46 AM
