1997 F350Dually
Old Jan 21, 2013 | 09:42 AM
ccking56's Avatar
Default 1997 F350Dually
Mechanic replaced 4 injectors on drivers side of engine. Turbo doesn't seem to be boosting. Truck sat for about a month and was fine when I parked it.. I am confused. Engine runs good but it takes a while to build up road speed. Any ideas? This truck has a 7.3 power stroke with no modification done.
Old Jan 22, 2013 | 07:40 PM
10kimballj's Avatar
can you hear the turbo trying to spool?
Old Jan 22, 2013 | 07:56 PM
ccking56's Avatar
No. I see the blades turning and can barely hear it whistling. I also have a puddle if fuel in the valley of motor near the rear
Old Jan 22, 2013 | 08:25 PM
10kimballj's Avatar
most likely fuel pump is leaking or for some wierd reason the two fittings near the back of the head behind the turbo
Old Jan 22, 2013 | 08:30 PM
ccking56's Avatar
I took it to a mechanic. This is over my head. Thanks for the help and I will check that fuel leak. Will the fuel leak keep the turbo from boosting??
Old Jan 22, 2013 | 08:41 PM
10kimballj's Avatar
yeah you need fuel to make boost
Old Jan 22, 2013 | 08:43 PM
ccking56's Avatar
Ok thanks a lot you have been very helpful.
Old Jan 22, 2013 | 08:44 PM
10kimballj's Avatar
yup no problem
12vWoodHauler
Sep 30, 2015 07:58 PM
Dye Guardian
Aug 1, 2015 01:28 PM
dieseldeal
Mar 24, 2015 12:11 AM
OBSBEN
Jan 3, 2015 07:50 PM
Jackson Gregory Scott
Nov 1, 2014 04:06 PM
