what did i do wrong with my ve-pump?
Old Jan 20, 2013 | 07:24 PM
Rusty89Cummins's Avatar
Default what did i do wrong with my ve-pump?
so im trying to figure out what i did to my injection pump. a little while back when i tried turning my pump up a bit more i thought i could adjust my idle down by moving the lever outlined in red so it was all the way up against the bolt outlined in blue. after helpin a guy turn up the pump on his truck i tried to do this thinkin it might help with bringing the idle down but then realized it might the truck run almost worse than it did stock so we put it back. after that i moved mine back to where it is supposed to be and it made a big difference. it runs like a completely different truck. so does anyone know what i did wrong by moving that lever?
Old Jan 20, 2013 | 08:58 PM
Red_Rattler's Avatar
High Tech Redneck
That adjustment bolt/slot positions the throttle-shaft in relation to the throttle-lever and yields big changes in either direction as you found out
Old Jan 20, 2013 | 09:14 PM
ahh i see. do you know if it would it give it a positive affect if i move it in the other direction?
Old Jan 20, 2013 | 09:28 PM
92betsy's Avatar
Experiment and google, then you will learn your own truck.
Old Jan 20, 2013 | 09:46 PM
already planned on playin with it if i dont find more info on it. just figured id ask and put it out there.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
greenbomb
Jan 23, 2015 10:36 PM
