LB7 Surging at hwy speeds.. NEED ADVICE!!
Old Jan 20, 2013 | 02:05 PM
SDA88's Avatar
Default LB7 Surging at hwy speeds.. NEED ADVICE!!
Hello everyone, I have 2002 duramax completley stock, the truck drives with no issues below 100km/h anything at or above that speed the truck starts to surge, the truck has a new injection pump and regulator 500km ago, the truck did it before the new pump and still does it after, any help or advice on this problem would be greatly appreciated.. thanks!!
Old Jan 20, 2013 | 09:12 PM
Red_Rattler's Avatar
High Tech Redneck
Any tuning any after market gauges?
Old Jan 21, 2013 | 06:07 PM
SDA88's Avatar
completely stock, no tune and no gauges
Old Jan 24, 2013 | 04:27 PM
CCPerformance.com's Avatar
Did they change the fuel filter after the instal? What kind of shape is the filter assem? I've heard these can get vacuum leaks and suck air.
Also on the tank end, I've heard of guys getting the "foil tops" from fuel additives in their gas tank that then get sucked up by the fuel pickup. That may cause a surge or starvation as well.
Old Jan 27, 2013 | 10:54 AM
carlc's Avatar
I HAVE THE SAME PROBLEM I PUT NEW INJECTORS IN AN STILL HAVE THE SAME PROBLEM I HAVE NO LEAKS AT ALL
Old Feb 1, 2013 | 11:38 PM
puddlestomper's Avatar
I just bought a 2002 3500 HD. It does the same thing only above 60 miles per hour.
Sent from my SCH-I500 using Tapatalk 2
Old Feb 1, 2013 | 11:39 PM
Mine only has 108,000 miles
Old Feb 2, 2013 | 03:10 PM
At 1900 rpm, it is barely noticeable. At 2000, it is definitely there. at 2100 it is unbearable. If I accelerate without down shifting it goes away.
"There is nothing like the hunting of men....."
Old Feb 2, 2013 | 08:43 PM
SDA88's Avatar
heres the latest and greatest now, pulled the injectors due to the common lb7 line corrision and there was lots of debris on the top of the injectors figured it might be causing my surging issues and it needs to be cleaned anyways, so cleaned the injectors, hard lines, return lines, replaced all the rubber hoses, torqued everything to factory specs, rebuilt the fuel filter head, took the truck for a drive and its still surging and the crankcase was loaded with diesel.. where did i go wrong and anymore help and advice would be great
Old Feb 4, 2013 | 04:34 PM
I changed my fuel filter. No change. Going to log it with EFI Live tonight or tomorrow and see what I can decipher with a little help.
