ect eot question
Old Jan 19, 2013 | 02:36 PM
flipskid's Avatar
Default ect eot question
OK so i did purchase the edge monitor for my 04 with 60K on it. I also installed the coolant filter. Everything seemed fine while driving. Towing the boat, 21 arima hardtop, over a decent grade i sometimes get more then 15 degree difference, but it quickly goes back into compliance. is this ok, or should it NEVER be more then the 15 degree difference once warmed up? Still has the stock egr/oil cooler. thanks JR
Old Jan 19, 2013 | 02:52 PM
Karls03's Avatar
Concern yourself with how the numbers look unloaded, flat and level, at 65~70 mph, at operating temperature. Loaded is going to show a higher split because the truck is working. While I wouldn't disregard them completely, I wouldn't use them as a basis to the oil cooler's health.
Old Jan 21, 2013 | 02:06 PM
Mdub707's Avatar
Realistically it should NEVER be more, but it's probably not as bad if it's doing it while you're hauling up a hill.
Old Jan 25, 2013 | 10:27 AM
flipskid's Avatar
Default eot vs ect
thanks guys for the response. so what is normal temps for you guys and normal differences during operation? does the difference change when you guys put it under load? thanks J
Old Jan 25, 2013 | 10:52 AM
Mdub707's Avatar
I'm not sure my numbers would help much, I don't know that I've ever tried recording it when my headgaskest weren't shot. I was recording mine a couple weeks ago, temps stayed within 3-7* of each other on flat ground, going uphill my coolant shot up to 20* above oil, which is backwards for an oil cooler, so my cooler is probably fine, but my gaskets are poop.
Dodge2006/5.9
Jul 20, 2015 01:21 PM
dieseldeal
Mar 24, 2015 12:11 AM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
