looking at a 06 need some advice
Old Jan 17, 2013 | 10:08 PM
Smarty=Cummins's Avatar
Default looking at a 06 need some advice
So im going to look at a 06 reg. Cablong box with a 6 speed. It has 100hp injectors, bad o parts, 62mm turbo, arp head studs, cold air intake, south bend dual disk clutch has gauges. What should I look for on this truck im New to these 3rd gens.
Old Jan 18, 2013 | 08:44 AM
dangerous1965's Avatar
Sounds like it has everything for a great start! Put a Smarty in it and 600hp is easy!
How many miles on injectors? Does it have a lift pump with extra filtration?
Old Jan 18, 2013 | 09:47 AM
It has 165,000 on truck n 2000 miles on motor #6 piston rings broke so he bored it 20 over. It has stock lift pump.
Injectors have 2000 miles.
Last edited by Smarty=Cummins; Jan 18, 2013 at 09:47 AM. Reason: Automerged Doublepost
Old Jan 19, 2013 | 11:44 AM
mykaos's Avatar
Take a jack and check out front suspension, steering components (2wd or 4wd). Pay particular attention to the hubs. W/ the front tires up, see if there is any side/side movement. While drving listen for "popping" sounds (bad end links/ tie rod ends). Check function of A/C & heat both for vent temp output ( is it hot or cold, don't need exact temps) & correct vent function (blend doors tend to fail). Look at the injector line isolaters. A "modded" truck can either be a good thing, stuff has been done, "or", stuff has been done and it has been beat on.
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
twm011
Feb 24, 2015 09:11 AM
jrsavoie
Feb 6, 2015 09:44 PM
lifted07sierra
Nov 6, 2014 08:24 AM
