recommendation on antifreeze
Old Jan 16, 2013 | 07:50 PM
chuffysplace's Avatar
Default recommendation on antifreeze
My truck is new to me. 85K on it. I've been changing all fluids and the last one left is the antifreeze. I'm reading that a low-silicate antifreeze is recommended. Is this true? Any recommendations on any brands or anything? Is good old Prestone good enough?
Old Jan 17, 2013 | 09:37 AM
tiremann9669's Avatar
Prestone is what I run.
Old Jan 17, 2013 | 09:42 AM
RAW's Avatar
RAW
I'm running NAPA coolant. From what I have heard/read/been told, engines with Aluminium components are the the most picky to coolant. Not much, if any, aluminum in our trucks.
Old Jan 17, 2013 | 12:25 PM
joecool911's Avatar
If you're worried, add a bottle of Wix radiator additive has anti corrosion in it. Antifreeze that has the Cummins label on it has anti corrosion stuff in it. Use cheap antifreeze and add the Wix.
Old Jan 17, 2013 | 04:23 PM
shellinger's Avatar
you may want to consider changing your thermostat out while you are changing the coolant. so you dont have to worry about dumping it out later.
Old Jan 17, 2013 | 05:37 PM
Thanks all. sounds good on all accounts. Yes...I want to change my stat too, that's what started this actually. I figure why not change the hoses too, there are original. Thanks again.
harrysteven
Sep 29, 2015 04:23 PM
Dieselnube
Mar 25, 2015 07:40 PM
jorttel
Feb 22, 2015 09:50 PM
tumble72
Nov 20, 2014 12:31 AM
