exhaust wont seal
my exhaust housing to = down pipe is leaking i cant get the fer to seal ive loosened dp and took clamp off and tightened but it still leaks any ideas? thanks
Ya may have to loosen a couple of joints to provide additional "play", adjust the DP, then tighten the DP first, then re-tighten the joints previously loosened. You also may want to try a new clamp, as the old one might be "stressed" or "stretched" not having enough clamping pressure. As a long shot, check your motor mounts as well. Maybe there is too much movement in the engine causing the exhaust pipe to bind against the body or frame and stress the DP connection. Hope this helps.
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
