Grid heater troubles
Old Jan 15, 2013 | 12:31 PM
1stgencumminsdenis's Avatar
Default Grid heater troubles
Im noobish when it comes to grid heaters how can i tell of mine isnt working because the wait to start light doesnt stay on for my than two seconds even when its extrenely cold, when it does start it bellows white smoke aany help?
Old Jan 15, 2013 | 12:54 PM
Screamin' Metal's Avatar
Well, you should turn on your key, you should be able to count to 5 slowly....Thousand1, Thousand2......so on, then you should hear a thud on your drives side fender, ( Heater relays), then you should start it.
Hook up a multi-tester to your grid heaters. When its cold they should have power once the ignition is on. Then after the thud, should have no voltage. If you do have voltage, place your hand by the intake horn. This area will get hot fast, be warned. Have someone cycle the switch, move your hand before it gets too hot. If its hot, your heaters are working.
If not, and you have voltage, your heaters have taken a dump.
If no voltage, go back to your heater relay. Make sure its getting voltage when you turn the key on. If there is no voltage coming out when its cold, the relay is bad.....
Old Jan 15, 2013 | 05:49 PM
montepig72's Avatar
Isn't there some kind of temperature sensor as well? I am having a similar problem, but I have already verified that the relays are working, but haven't located what controls them yet.
Old Jan 15, 2013 | 06:13 PM
Yes, it senses temperature....thats how it knows to come on....
NadirPoint
Status: Back.
My Diesel: 1991 SRW 5sp 4x4
Casino Cash: $183324
Threads: 45
Originally Posted by jshafley
my wait to start light does not come on at all when its cold but when its warm it does.
Sounds like maybe somebody at some point installed the wrong sensor. They are different between I/C vs. non-I/C. That is the only thing I can imagine that would explain such backwards behavior. I say this because the KSB is electrically opposite in the I/C vs. non-I/C (hot/off) and also activates through one of those sensors.
Last edited by Screamin' Metal; Jan 15, 2013 at 06:13 PM. Reason: Automerged Doublepost
Old Jan 16, 2013 | 09:07 PM
montepig72's Avatar
Let me clarify. I have the same issue that the grid heater seems to have stopped working under let's say 35 degrees. No parts of it have been replaced ruling out a possible wrong temp sensor. Everything was working fine until about 2 months ago when it started getting cold. What I was getting at is maybe there is a "bad" spot in the sensor causing it not to work at certain temperatures. It sounds like the OP's problem is very similar. My question is not if there is a sensor, but does anyone know where it is.
Old Jan 17, 2013 | 10:26 AM
The temp sensor is in the intake on the head.....heres a pic....
1991 1993 Dodge RAM 5 9 Cummins Diesel Air Intake Temperature Sensor Map Sensor | eBay
its wired into the heaters. I just wire in a momentary switch, when its cold I just push the button for 5 seconds. And if its really cold, I can press 5 seconds release of a second, hit it again for 5 seconds....that way I keep the wear off my ignition switch....
Old Jan 17, 2013 | 12:03 PM
H.R.D's Avatar
It is the IAT sensor (Intake Air Temperature) located on the drivers side either on top or below the intake plenum and behind the intake manifold (horn). Take it out and clean or replace.
The below PDFs are for 94+ 12v and 98.5+ 24v but the process and values should be the same....
File Type: pdf
Old Jan 17, 2013 | 02:36 PM
montepig72's Avatar
Thanks guys, that helps me a lot and hopefully the op as well.
dodge2014
Apr 16, 2015 08:54 PM
95 cummin
Jan 21, 2015 11:54 AM
Rooster24v
15
Jan 4, 2015 08:20 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
justinsbeck
Nov 22, 2014 03:03 AM
