quadzilla questions
Old Jan 14, 2013 | 07:33 PM
blackdiesel's Avatar
Default quadzilla questions
I am installing my quadzilla pulse v2 right now and have some questions...first off how come my tranny heat sensor dont go in all the way is that normal? also I herd if you had a stuck tranny you should not use the vp pump tap is this true? will I still see gains even with out this wire? also how do I download tunes on to this?
Old Jan 14, 2013 | 08:31 PM
shellinger's Avatar
go to quadzillapower.com scroll down the page a little and you will see a yellow tab on the left hand side that says usb updates and click on it and select your adrenaline for your year dodge cummins. you can choose the 1000 tunes, 2000 tunes or beta tunes. i would try and stay away from the beta tunes because some of them can hurt your motor and tranny if your not careful. but in order to download any tunes you need the usb cord to connect to your tuner. you download what ever you tune you want then click on it when it finishes downloading. a small window that says quadzilla will pop up. at that time you can connect your programmer to your usb port on your computer. then press get info from module. when it recognizes the programmer and says module found then click the button that says update module. then it will have say something like loading new program and when it says finished loading then you can disconnect your programmer and connect back up to your truck. not sure about the trans temp probe. i have manual trans. i would connect the pump tap no matter what because only level 0 is stock with boost fooling the rest of the levels turn the pump up. im not sure what a stuck trans is but i think you need to hook up that wire. if you have any questions you cant find on here the quadzilla customer service is pretty good. give them a call and they will walk you through it.
Old Jan 14, 2013 | 08:51 PM
I ment stock...and also how there are so many updates do I just get the newist one or what?
Old Jan 16, 2013 | 06:21 PM
shellinger's Avatar
if you are having tranny trouble i would stick with one of the 2000 tunes, they are all the same amount of power in the 2000 tunes but you can put like a turbo timer on, warm up mode, a high idle if you leave your truck on and dont want to worry about cylinder wash. if you are looking for massive amounts of power i would recommend the adr 3000 tune which gives you tons of power but then you run the risk of breaking stuff more easily.
Old Jan 16, 2013 | 08:50 PM
what are the differences between the 1000 and 2000 series?
Old Jan 17, 2013 | 04:14 PM
shellinger's Avatar
that i am not sure of. if you have time i would give quadzilla customer service a jingle and see what they say. i am not sure if the 1000 has less aggressive fueling than the 2000 or not so i dont want to say.
Old Jan 18, 2013 | 10:30 PM
do u load tunes on to the pulse or the computer it self???
Old Jan 18, 2013 | 10:40 PM
2000 is more aggressive with Beta being the most aggressive.
Luke
Old Jan 19, 2013 | 02:30 AM
OK...do I load the tunes to the aderinal module or onto the pulse?
Old Jan 19, 2013 | 08:17 AM
They are loaded onto the Adrenaline. You can do custom tuning yourself through the Pulse.
Luke
