Oil pan
Old Jan 14, 2013 | 11:42 AM
Highlander's Avatar
Default Oil pan
Is there much work involved in changing a oil pan on a 98 6.5, do i have too lift the motor?
thanks
Old Jan 14, 2013 | 05:50 PM
acesneights1's Avatar
No, you have to drop the front axle. it's a royal PIA. I don't remember having to jack the motor but I know I dropped the front axle .
Old Jan 14, 2013 | 07:15 PM
Highlander's Avatar
That's not good.. gotta check it out tomorrow and see what's up with dropping the Axle.
Old Jan 15, 2013 | 12:43 PM
cviola2005's Avatar
Would it be easier to lift the motor a few inches? Rather than dropping the axle?
Old Jan 15, 2013 | 01:00 PM
Highlander's Avatar
I use this truck to work every day, is there any way I could patch it up for now.. how about JB weld, if I sanded it down and cleaned it up.
Old Jan 15, 2013 | 09:13 PM
cviola2005's Avatar
The only problem I have found with JB Weld is that it softens up with higher temperatures.
How bad is the problem?
Old Jan 16, 2013 | 04:57 AM
Highlander's Avatar
It's just a small leak..only a few drops on the ground after setting all night.
Old Jan 19, 2013 | 06:28 PM
no You cannot get it off that way. You must drop the axle. It's not that bad.
Drain the oil. Then braze it. You may need to reprime the motor. Be careful when you go to start it after putting the oil back in. If you start it and don;t have oil pressure after a few seconds, shut it off and pull the oil pump drive and hand prime the pump.
Last edited by acesneights1; Jan 19, 2013 at 06:28 PM. Reason: Automerged Doublepost
freak-n-diesels
Aug 23, 2015 06:47 PM
CRCSI
Mar 29, 2015 11:26 PM
98cummins
Jan 29, 2015 08:23 PM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Jan 7, 2015 03:42 PM
98cummins
Dec 9, 2014 10:14 PM
