1999 24 valve Transmission oil leak
Old Jan 13, 2013 | 12:18 PM
jbuck's Avatar
Default 1999 24 valve Transmission oil leak
Son was driving the truck when it started to slip. He pulled it over into gas station immediately and noticed trans fluid pouring out of it from under engine not compartment not tranny area. I have not seen the truck yet plan on going out to station tomorrow to look at it. What lines should i be looking at and where do they run?
Old Jan 13, 2013 | 02:21 PM
RAW's Avatar
RAW
Transmission cooler lines. Flow goes from the trans to the heat exchanger on the right side of the engine. From there is goes to the cooler at the front left corner of the cooling package. Most likely there is a bad quick connect at the front left of the engine.
Old Jan 14, 2013 | 05:50 PM
jbuck's Avatar
Thanks guys, i just purchased the truck and when PO had the transmission rebuilt they zip tied the cooling lines together. Does not take long until vibration creates a hole in lines. My 12 valve had the same thing happen but was covered under warranty.
Thanks again.
cummins Pride
Sep 28, 2015 12:11 PM
Jake12valve
May 10, 2015 11:57 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
