92 cummins piston lift pump
Old Jan 12, 2013 | 11:45 AM
1stgencumminsdenis's Avatar
Default 92 cummins piston lift pump
So i bought a new left pump as mine is leaking, is changing this pump fairly simple or should i be paying someone to install it? Any body have a how to video, i assume with a leaky lift pump the grid heater can malfunction? Is this also true?
Lift*
Last edited by 1stgencumminsdenis; Jan 12, 2013 at 11:45 AM. Reason: Automerged Doublepost
Old Jan 12, 2013 | 12:50 PM
1stgenblowingsmoke's Avatar
No your grids won't screw up.
Which piston lp did you get? the low pressure LP or the high pressure 2nd gen LP that needs a regulator?
Old Jan 13, 2013 | 10:32 AM
Its the stock replacement pump mines leaking and getting air in the lines somehow
Old Jan 13, 2013 | 01:42 PM
Screamin' Metal's Avatar
Also, The stock pump will last a long time, but think about this. If you loose a diaphrame in your pump, you could pump your crankcase full of diesel fuel.
Whenever I have the chance to change one out, I block the old pump hole off with a Chevy blockoff plate, then wire in a good quality electric pump hooked to a hobbs switch. I have a good quality Racor spin on filter before my fuel pump to help protect it, and it helps scrubb the already prefiltered WMO that I run in my truck.
This does 2 things, if you ever loose oil pressure, the pump turns off and stops your engine before it goes south, and it also pressurizes your system, so when you change your filter, it helps prime it. Also, if you ever run out of diesel, your motor will start quicker since its being pressure fed....
Old Jan 13, 2013 | 07:27 PM
geddy's uncle's Avatar
You just sailed something right over my head. What's a hobbs switch?
Old Jan 14, 2013 | 12:35 AM
A hobbs switch cuts power to the fuel pump once the engine loses oil pressure incase say your turbo feed line blows you won't ruin the engine or have a lesser chance of it.
Old Jan 14, 2013 | 10:00 AM
Where wpuld i get an electric pump like that hpw much of a dent is gonna be in my wallet
Old Jan 14, 2013 | 10:01 AM
blackduck's Avatar
Hobbs is a particular brand, oil pressure switch in plain terms. Good switch's though
Old Jan 14, 2013 | 02:20 PM
yeah I was way to tired to think lastnight,
Anyway holley black fuel pumps work good on 1st gens with a regulator.
Old Jan 14, 2013 | 05:07 PM
How much do they cost
