Heater
Old Jan 11, 2013 | 08:12 PM
joecool_2002's Avatar
Default Heater
I have a 98.5 cummins 24v, the heater is stuck on defrost and it wont change? I checked the vacum hoses and they appear good. Any suggestions?
Old Jan 11, 2013 | 10:53 PM
jbuck's Avatar
Its got to be one of two issues. Vacuum leak on one of the hoses or rubber elbows or a damaged blend door which controls airflow. The only way to really check for a leak is with a vacuum pump. Check the line starting at the nipple coming off the vacuum pump near the power steering pump and work back to the firewall. The rubber elbow on my 24valve was very brittle.
Good luck
Old Jan 12, 2013 | 12:01 AM
Nutty Jeeps's Avatar
I had this issue last fall. Mine was a vacuum leak on one of the lines that ran across my firewall.
Old Jan 13, 2013 | 06:34 PM
thanks guys ill check it out
Old Jan 14, 2013 | 10:06 AM
jbuck's Avatar
Default Vacuum schematic
Joecool this might help
Old Jan 14, 2013 | 04:52 PM
thanks i found it, was broke along firewall.
kelchy82
6.2L & 6.5L Performance
10
Nov 27, 2016 04:32 PM
Mike H
Jan 25, 2015 10:08 AM
94_12v
Jan 4, 2015 10:37 PM
bikernut
Audio Equipment/Electrical
Dec 18, 2014 03:30 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
