Tranny patern
Old Jan 10, 2013 | 05:29 PM
acesneights1's Avatar
Default Tranny patern
Does the Cummins have the same bolt pattern and would it hook up to a 727 Torqueflight ?
I have an old Dodge camper with a 440 in it and I would like to put a Cummins in it. If not what would be the simplest tranny(2wd) to use with a Cummins. The camper weighs 14,000 lbs.
Old Jan 10, 2013 | 05:43 PM
NadirPoint's Avatar
Nope, BB bolt pattern won't fit.
Will the chassis and engine bay work without major mods, or is this a no-holds-barred no-fab-job-too-tricky type build?
Old Jan 11, 2013 | 07:09 AM
Let's just say I have a welder and a torch and it can be done....: )
The newer trannys with electronics is what I am not sure about. Looking for a tranny that has minimal to no electronics to deal with, has OD , will bolt to the Cummins and can handle the weight.
Old Jan 11, 2013 | 08:25 AM
BIGREDGOAT's Avatar
Getrag nv4500, nv5600, g56, g56r
Sent from my C771 using Tapatalk 2
Old Jan 11, 2013 | 01:17 PM
Its gotta be an auto. In a motorhome.
Old Jan 12, 2013 | 09:14 AM
blackduck's Avatar
Sorry too far away to help, have an Allison AT 545 off a 93. Requires an SAE bell housing
You should be able to find them fairly easily, mine came out of a F600 with a 160 Hp 12V. They are rated just above a fairly stock 5.9 12V but knowing Allisons they can take a fair amount of work.
Cheers Steve
Old Jan 14, 2013 | 07:51 AM
plowboy1138's Avatar
A518 or 47rh would be fairly simple
Old Jan 14, 2013 | 10:33 AM
blackduck's Avatar
there is or was a couple of A518s listed elsewhere for sale, another site
Old Jan 14, 2013 | 06:08 PM
Does the allison have OD ? what is the final ratio ?
Is an A518 electronic ?
Old Jan 15, 2013 | 10:09 AM
blackduck's Avatar
Allison AT545 are not overdrive, some A518's are.
InheritedDiesel
Jun 3, 2015 09:39 PM
wilki
Feb 12, 2015 09:04 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
Ol' RED!
Dec 11, 2014 10:00 AM
Trevlar11
Nov 16, 2014 01:59 PM
