no power on hills
Hello I have just bought a 2000 cummins 24v for a work rig now the only things done to it is a boost fooler ( local shop said it had stuck wastegate and this was cheap and easy fix ) Airdog lift pump and a new injection pump a month before i bought it the truck has no stored codes either now this is truck is a utilty work truck and a dully so it is heavy ( about 9700 lbs empty ) I live in a hilly area and I can only do about 50-55 Mph up hills it runs great any ware else is there any cheap mod's or tunner's I can get to get some extra power? or is something wrong?
Um you should be able to fly over hills, my truck weighs 9200 at 8000 feet and she climbs the passes with 10K no problem try to get it checked for codes? and its proably has close to 200K and may need valve lash.
