More mods?
Old Jan 9, 2013 | 11:08 PM
Powerstrokin7.3's Avatar
Default More mods?
Hey Im looking for any more mods I can do on my 94 idi turbo vin k ill put out a list of what's done but if anyone has more ideas or thoughts I could do to get a little more hp and torque thanks appricate it
Replaced factory turbo with banks sidewinder
New injectors done around 6 years ago
Trans rebuilt with shift kit 12k ago
Transfer case done 12k ago
3in down pipe and straight piped back
Intercooler added on
Injector pump turned up
Cold air intake
8 new motorcraft glow plugs
Banks trans command modual
Old Feb 3, 2013 | 09:53 PM
fordidipower's Avatar
coolingmist meth injection and ARP head studs and turn up the boost .
Old Feb 3, 2013 | 09:56 PM
I've never messed with that meth injection is it pricey ? Or hard ? And the pump is turned all the way up and the studs are gettin done in the summer along with headgaskets of Corse
Old Feb 3, 2013 | 10:07 PM
its about 300 for a kit and its cheap you dont even have to run meth you can just use distilled water and it will do wonders for your truck. you just cant fet crazy and hydro lock the motor. do dome research on google or on here and decied. i like it though and if you tow anything its a must in my opinion. it cleans cools and adds a touch of power. go to coolingmist.com and check it out
Old Feb 3, 2013 | 10:11 PM
Yeah ill definitely check I out now thanks appricate the input now I just have to find a rear end cause its about to blow out haha I want to geta set of new axles with better towing gears and not 3:55s
Old Apr 1, 2013 | 03:09 PM
7.3idiboy's Avatar
a water meth kit it wall woth the chipps i got a snow performance one and it added so much power its crazy and and cools your exhaust temp. its really a big help when hauling. you could also turn up your wategate for about 12 psi
Old Apr 2, 2013 | 10:27 AM
Yeah it's gonna be expensive though right ? And my pump is already turned all the way off and the wastegate is taken off and closed I can push over 15 psi I I hold the pedal on the floor. I would love to have water meth but how much is it gonna cost cause I can't find one for 300 like the other guy said
2004LB7
29
Feb 29, 2016 06:00 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
lb7Garrett
Chevy/GMC Duramax 01-04 LB7
Feb 15, 2015 09:02 PM
dieselpowa
Jan 26, 2015 03:02 PM
rtbcoop
Dec 30, 2014 02:13 AM
