Opinions on Hx-40
Old Jan 9, 2013 | 07:42 AM
1stgenbomber's Avatar
Default Opinions on Hx-40
Looking for advice on hx-40 1st gen swap
Old Jan 9, 2013 | 07:56 AM
RAW's Avatar
RAW
Did you already get a HX40? THey are know for weak shafts. IMO, you would be better off making a HX35/40 hybrid and running it.
Old Jan 9, 2013 | 08:20 AM
No I haven't just wanting to figure out soon what turbo to run
Old Jan 9, 2013 | 08:26 AM
RAW's Avatar
RAW
A HX35/40 upgrade is relative cheap and reliable. $300-$400 for parts and machining to get into a 60mm turbo. Another $165 for a larger turbine housing if drive pressure becomes an issue.
Old Jan 9, 2013 | 11:29 AM
Screamin' Metal's Avatar
Hee-Hee, what he said!^
Old Jan 9, 2013 | 01:41 PM
What kinda performance should expect / boost ?
Old Jan 9, 2013 | 02:26 PM
RAW's Avatar
RAW
I've heard of up to 50psi with a HX35/40. Turbine housing size will determine drivability. A small housing will spool quicker, but will choke the engine under high boost. Even a wastegate can't handle all the drive pressure at times.
Old Jan 9, 2013 | 09:23 PM
GrudgeGuy's Avatar
Isn't that only an issue with trucks that have a ton of fuel supply like P pump pullers
Old Jan 12, 2013 | 08:57 AM
peobryant's Avatar
Yep, I've only heard of HX40's snapping shafts when people are running way too much fuel for the turbo and constantly bark them. Mainly trucks with the P7100. A Super HX40 has a stronger shaft and is a better turbo than a regular 40 so that's the one I'd go with.
I know a man who's had a 400rwhp 1st Gen with an HX40 (don't believe it's a Super) for years as his tow pig and he's never had an issue with the turbo.
Old Jan 13, 2013 | 01:56 PM
Yea, what they said! I love building my own stuff, thats why I own my own shop. I love duals. Yes the 35/40 hybrid is great, the 40 is best though. The 35/40 is the way to go if $ is against you.
If you want all around performance, great driveability, do a dual system with the HX35 on the bottom and the 45 up top.
You'll gave great off idle pull and before the 35 runs out, the 45 has taken over.
I don't run the waste gates, I use the popoffs and have mine set right at 42. At 45 and up, ERG's are getting up there with a long hill and pulling a heavy trailer. The 45 can hit 50 PSI if you can't popoff or use the pressure.
I also throw a little cold propane in the mix there to help keep the heat down....helping burn all the fuel.
