Convince me to do cab lights
Old Jan 9, 2013 | 12:34 AM
RanchhandTCR's Avatar
Default Convince me to do cab lights
Hey guys,
Well I got a raise from my job so I can afford more stuff. Id like to do cab lights but out of all the articles I have read Im still scared to even attempt it. So I wanna see if you guys can convince me to drill holes in my truck. For you guys that have done this can you tell me what bits and hole saw size I need? thanks guys.
Old Jan 9, 2013 | 01:18 AM
joecool911's Avatar
Pull down the headliner in the front. You will see holes in the cab framing where lights should go. Drill 1/8" holes up through the middle of the large holes in framing. The. Get on top and drill down larger holes. Around half inch. I used a dial caliper to measure the size of the wire connector and used just a bit bigger bit. I used the Recon LED cab light set. Came with a harness. One screw in the cab frame for ground and a tap connector on the wire on the back of the headlight switch. Position lights and drill mounting screw holes using lights as a guide. Use pleanty of silicone caulk in screw holes and wire holes. Screw down the lights and replace headliner.
Did mine about a month ago.
Old Jan 9, 2013 | 08:06 AM
RAW's Avatar
RAW
I can't help convince you, sorry. I don't like cab lights.
Old Jan 9, 2013 | 08:21 AM
Mikeh1725's Avatar
Cab lights increase your chances of a leaky roof, just saying.
Old Jan 9, 2013 | 08:32 AM
it dont rain here anyways ...
Old Jan 9, 2013 | 11:03 AM
tiremann9669's Avatar
I have the Lund Moonvisor with lights in it, only 4 small holes in cab, less chances of leaks, plus it helps keep the sun out of my eyes. The screws that come with the visor come with wax on them I think wax holds up better than caulk because caulk tends to crack after a few years.
Old Jan 9, 2013 | 11:58 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Perfect description joecool911
Old Jan 9, 2013 | 11:03 PM
Hummin Cummins's Avatar
Diesle pickups and cab lights go together. Don't look right without
Old Jan 10, 2013 | 12:13 AM
Ramitt's Avatar
If you know what you are doing and arent scared you can do cab lights. This is on a 3rd gen so a little bit more work but same concept.
crashmarvin
Jun 15, 2015 07:10 PM
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
