welding
Old Jan 9, 2013 | 04:39 PM
yfzrunner's Avatar
Default welding
is it bad to weld a exhaust hanger to a frame jw.And its actually just on the rear subframe i guess were the gas tank is bolted to about a 2 inch weld. Some say make frame weak
This is what im talking about you. You think any damage happened it did get red hot. But just a small weld.
Old Jan 9, 2013 | 05:13 PM
RAW's Avatar
RAW
It will be hardened in that area, and will be more prone to cracking compared to the rest of the sub frame. I doubt you will ever have an issue though.
Old Jan 9, 2013 | 06:35 PM
yfzrunner's Avatar
bummer i do got a 5th wheel welded in so should also work as a cross member so who knows. I told them not to do it to the frame so they did it to the crossmember geez.
Old Jan 26, 2013 | 10:44 PM
mudsling's Avatar
depends on who you talk to....ive got my certifications for welding and the text book answer is not reccomended will harden and create a "soft spot". my opinion is go for it iver done it multiple times and never once had an issue. hope this helps!
