no start ? simple fix?
Old Jan 5, 2013 | 02:22 PM
living_chevy's Avatar
Default no start ? simple fix?
Ok first off im not sure if this is why but my truck is a electrical nightmare. Speakers pop when everything is shut off my fuse box shorted out one while making a turn anyhow..
Truck wont start after attempted master and slave replacement. However store gave me wrong parts and i ran out of money, so i just re attached old ones. It started, i drove it to the store and back (5 min drive) then nothing. And note i have yet to get the slave to bleed i cant even bench bleed it, it wont drain from the master. Also synchronizers are going out i believe so it probably didn't help i was floating the gears because i couldn't bleed the system (no clutch pressure at all)
Truck. Attempts to turn all the way over if i do so in 1st the truck will roll bit nothing more,
my glow plug light comes back on while cranking the engine. I replaced the glow plug control, but no dice.
Its 6.5 3500 chevy
I checked fuel and lifters via filter bleeder and fuel drain hose. Diesel came out of both while cranking.
one neW battery on the starter side and fully charged 2nd.
Any ideas? I just want it to start
Old Jan 5, 2013 | 02:26 PM
acesneights1's Avatar
check all the wiring in the area your were working. Sounds like you messed something up. Check the grounds on the intake too.
The Slaves on these are a MF bitch to bleed. Also if the clutch fork is worn out on the pivot it will never bleed.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
