7.3 engine issues
Old Jan 5, 2013 | 07:12 AM
obsplaytoy's Avatar
Default 7.3 engine issues
I have a 96 7.3l F-250 with roughly 150k on it, the truck wont start unless I spray a small shot of either in the intake. once its running the truck sounds like its running on 3 cylinders. and idles so rough I cant have anything on the truck otherwise it falls to the floor. the truck had a short in the harness and fried my idm when it first drop dead on me. after I fixed that issue the truck started my new issue and barely idles. the truck has a new lift pump that probally has 45 min on it and new oil change all new filters, I ohmed out all of the wiring harness from the idm connector through the injectors and had between 3 and 3.2 ohms for every injector, I checked the oil level in my hpop and when took of the plug the hpop res was full, there are no fuses blown, and im probally forgetting other things ive checked or replaced. can someone help me with my issues with this truck thanks
Old Jan 5, 2013 | 10:19 AM
95powersmoker's Avatar
WHen you ohmed out the injectors, did you ohm the glow plugs? Does it start when you plug it in over night?
Old Jan 5, 2013 | 04:56 PM
obsplaytoy's Avatar
all 8 glow plugs and three of the uvc harness were replaced with new, and I checked the glow plugs from the valve cover gasket and they checked fine from there, I haven't checked the engine harness side because I could find any schematics on it
oh and while the engine cranks its blowing white smoke
Old Jan 5, 2013 | 05:45 PM
Thats good, means theres fuel being injected into the cylinders... have you checked your glow plug relay?
Old Jan 5, 2013 | 06:38 PM
obsplaytoy's Avatar
the relay is bad im assuming because when I turn the key on the relay starts buzzing and after 10 sec it'll start smoking so I have the relay unplugged, and the truck is sitting in a heated shop with a heater blowing on it, so engine is fairly warm and should still fire
Old Jan 5, 2013 | 06:44 PM
Replace the relay...
burndiesel
10
Feb 7, 2023 01:15 AM
boylesjesse
Apr 8, 2015 10:11 PM
stanzu
Feb 21, 2015 10:13 AM
krinderhagen
Jan 15, 2015 12:07 AM
krinderhagen
Dec 31, 2014 07:12 PM
