edge comp stacked with smarty
Old Jan 4, 2013 | 11:09 PM
Hoytshooter's Avatar
Default edge comp stacked with smarty
I have edge comp level 1-5 and Smarty s-03 1-8 I know to only run on even num wen stacked. What is best settings for fuel economy,towing exc........ with. Both chips or one or the other
Old Jan 5, 2013 | 09:52 AM
RAW's Avatar
RAW
For non loaded driving, I would run my Smarty on level 1, and the Edge on 1. Seemed to work well. When I hooked to my trailer, I would set the Smarty to a different level without added timing.
Old Jan 5, 2013 | 09:26 PM
So by level 1 u mean 2 because you can't have to chips doin timing at the same time. Wat are u getting for millage
Old Jan 5, 2013 | 10:56 PM
Nutty Jeeps's Avatar
1 on the smarty is fuel saver so you can run it on 1 but no other odd number tunes
Old Jan 6, 2013 | 10:14 AM
RAW's Avatar
RAW
By Level 1, I mean Level 1. The Mileage setting. Staying on the hiway I can get close to 600 miles per tank.
Old Jan 6, 2013 | 12:21 PM
Ok I thought u had stacked chips. I'm gonna turn of the edge and give it a try
Old Jan 6, 2013 | 12:22 PM
RAW's Avatar
RAW
I do have stacked chips, an EJWA and a Smarty.
Old Jan 6, 2013 | 12:28 PM
MADS Electronics - Smarty - CaTCHER - Smarty03
I can't use level 1 with my edge because edge does timing also so I have to turn edge off
Old Jan 6, 2013 | 11:07 PM
blacksally's Avatar
i got a smarty and run it on 5 all the time i see it says it has cold 3 cylinder idle??? how do i get that? i dont have a cord to update and i dont know how some times when i start it without being plugged in it idles up bc the cold but no 3 cyl idle and i have a high idle switch 1200 idle
RexShoppe
Price Quote - Request A Price
Nov 23, 2015 02:38 PM
Rusted Dragon
Feb 27, 2015 09:46 PM
scottxmorris
Feb 6, 2015 05:33 AM
FF131
Jan 21, 2015 11:37 AM
scottxmorris
Dec 31, 2014 03:20 PM
