Front end problems!!!
Old Jan 4, 2013 | 10:10 PM
jfollowell's Avatar
Default Front end problems!!!
I was driving home from work the other day and made a turn and heard truck make a popping noise in the front end. Well the only time it pops is when I shift gears. Mainly from 4th-5th at about 1700rpms. Don't pop when in the throttle but taking off if you run it up to about 2000rpms and let off the throttle it'll pop. Thought it maybe u joint going bad so had it replaced but still pops. Anyone experience this? Thanks guys
Old Jan 4, 2013 | 10:18 PM
mysterync's Avatar
Is your truck 4x4? If so I would probably look at the axle joints. A pop could be thousand of thing's really depends on what it sounds like.
Old Jan 4, 2013 | 10:29 PM
jfollowell's Avatar
Yes truck is 4x4. I noticed today that if your running highway speeds and you let off the throttle then get back in it, it jerks a lot harder than it normally did. And that's the only thing that worries me is it could be numerous of things. I don't believe it's tranny issue bc shifts as normal as it did the day I bought it.
Old Jan 4, 2013 | 10:39 PM
mysterync's Avatar
Pinion slap could cause this issue but i would think whoever installed your u-joint would have mentioned an issue. Transfer case issues could also cause something similar. Have you jacked it up and looked for play in the common locations.
Old Jan 5, 2013 | 04:41 AM
jfollowell's Avatar
No haven't really had time to get it in the air to check it out. But I've noticed that it sounds like the pop is coming from the passenger side. Starting to wonder if its just an axle u joint.
Old Jan 5, 2013 | 07:04 AM
Cody Cummins's Avatar
Mine also does this. This is a picture of my front end and check the bushing that i circled. Mines worn out and also slaps when i turn sometimes http://i590.photobucket.com/albums/ss345/Cody_Cummins/2013-01-05074007.png
Old Jan 5, 2013 | 08:00 AM
jfollowell's Avatar
Well whatever it was just went. Thinking wheel bearing now bc I hear a loud grinding noise and can't keep the truck straight I've 25mph and now my abs light and brake light won't go off.
Old Jan 5, 2013 | 09:21 AM
Sent from wheel bearings arent fun . I had one lock up on me oje time going down the road
Old Jan 5, 2013 | 09:44 AM
mysterync's Avatar
That doesn't really explain the play in and out of the throttle. axle stubs have the reluctor ring depending on the year, we just had a axle joint fail at the shop and take the stub out, and its very possible for it to take the bearing out. If the bearing was popping it would have been bad enough that you would have already heard a roar. Imo
Old Jan 8, 2013 | 03:50 PM
jfollowell's Avatar
Yea had the wheel bearing replaced and still didn't solve the problem. Had a buddy look at it this morning and he seems to think it maybe transfer case problems. I know one thing, I love my truck but she's about to make me pull my hair out.
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
2FordStrokers
Jan 11, 2015 09:40 PM
Cumminsman911
9
Nov 1, 2014 04:07 PM
