4x4 dually tranny
Old Jan 4, 2013 | 02:48 PM
k_nine's Avatar
Default 4x4 dually tranny
i took my truck for a drive the other day and it would not shift all i had was first gear.
it was like i had all 4 gears til it warmed up.
any ideas?
1998 gmc 6.5 turbo 4x4 duelly extended cab
thanks k_nine
Old Jan 4, 2013 | 03:05 PM
acesneights1's Avatar
It's an Auto I assume ?
Put a scanner on it and look for tranny codes. I assume you did the obvious and checked the fluid.
Old Jan 4, 2013 | 04:02 PM
k_nine's Avatar
ya its a automatic and it stinks real bad
and it was right up on fluid
just took the truck for a drive the check engine light came on. but i couldnt get the truck over 40 mph with out it revving up over 3000 rpm, and not pushing it
Old Jan 5, 2013 | 02:29 PM
Gotta get the codes...smelt real bad is not a good sign.
Old Jan 5, 2013 | 04:00 PM
k_nine's Avatar
i have a guy coming on monday with a code reader
Old Jan 5, 2013 | 09:30 PM
post em up.
Old Jan 6, 2013 | 08:02 PM
k_nine's Avatar
i will as soon as i find out
Old Jan 8, 2013 | 07:17 PM
Brandon3's Avatar
I would check output speed sensor on transfer case
I had the same thing happen too me.
On my 1995 chevy 3500 4x4
Old Jan 9, 2013 | 03:23 PM
k_nine's Avatar
thanks i wil look at that
ok
had a scanner put on my truck to read any codes, but the scanner would not connect to the computer. it wasnt a cheap scanner this guy is a class A mechic. called another garage and they said there could be a broken wire some where.
so i have a wire diagram coming to look for a broken wire.
not sure what to do now million wires to go though.
any ideas let me know
thanks
k_nne
Old Jan 9, 2013 | 04:13 PM
If you can't connect to the ecm I'd say that is part of your problem.
