I NEED HELP! no pressure in turbo
Old Jan 3, 2013 | 02:16 PM
CaliforniaCowboy's Avatar
Default I NEED HELP! no pressure in turbo
i have an 04 f350 6.0 turbo. i recently lost all power from the turbo therefore resulting in my truck running like crap and the transmission not shifting well. i replaced the egr. no improvements. i just had the turbo rebulit. i installed it and still no power from the turbo. i am now out of ideas and money. the rebuilt turbo got my engine light to turn off but i still had no power coming from it and poor shifting in my transmission. my engine light just kicked back on and the scanner blew a p2262 code. any ideas? i read on another thread try to bypass the cat will that work?
Old Jan 3, 2013 | 02:35 PM
Fourdoor's Avatar
https://www.dieselbombers.com/ford-p...2262-code.html
Old Jan 3, 2013 | 02:38 PM
bobfbigman's Avatar
You most likely blew a boot off or at least split a boot causing the lack of PSI, it is also possibe to split the intercooler. The best way to find it is to remove the intercooler tubes,pass and drivers side, inspect all the boots clean them with brake clean anddry off then reinstall. if you have the late 04 truck and have the plastic tube on drivers side check that over real good because they split often
Old Jan 3, 2013 | 03:05 PM
ok ill try checking the boots. to check the intercooler do i need to remove it completely?
Old Jan 3, 2013 | 05:47 PM
Fourdoor's Avatar
You can cap off one side and use an adaptor on the other to pressurize it with the intercooler still in the stock location.
Keith
Old Jan 4, 2013 | 08:01 AM
Mdub707's Avatar
Check the boots first, not terribly common for an intercooler to crack, but it can happen. I'd check that last.
avatardvr
18
Aug 8, 2019 12:38 AM
robbyS
Apr 16, 2015 02:22 PM
n2brk
Feb 21, 2015 09:05 AM
veggyoilkid
Nov 10, 2014 12:39 PM
GreenDieselF
Oct 20, 2014 02:05 PM
