08-13 mirrors?
hey guys question!?
my buddy just bought a 2013 kr f250. he let me drive it and i love his mirrors
! is there any way to put those mirrors on my 06. Also is the wiring diagram the same?
thank you
! is there any way to put those mirrors on my 06. Also is the wiring diagram the same? thank you
the mirror wont just hook up and plug in to my harness?
The $1900 is for power everything
2008 Ford Super Duty Towing Mirror Retrofit Kit for 99-2007 F250 F350 F450 Trucks
i have been researching the same exact thing. from the best of my knowlege they do blot up. the wiring on the other hand, they are not the same wiring diagram. do you would have to figure that one out, or im sure there is a diagram floating around somewhere on google. the only other thing that you would have to work around is the power teloscoping power folding.
what i was planning on doing is just running a time delay relay off of something like the security light and use that to have then automaticly fold and teloscope as soon as the truck turns off.
but then again i am a aircraft electritian so i know all these fun things you can do
Keith
The easiest way I would do some '08 mirrors are to use the power/heated ones. The power fold/telescopic is just too much to deal with. A wiring schematic would be best to help. Take apart the old connector, take apart the new connector. Place the new mirror wires in the old connector using the same layout. I.E> mirror heat Pin 1, power tilt Pin 2, ground Pin 3...etc etc. The OEM connectors come apart easily to fix broken pins. I hate to cut-n-splice.....
