truck wont shut off when i turn the key off
Old Jan 3, 2013 | 12:13 AM
Massingale1's Avatar
Default truck wont shut off when i turn the key off
my truck wont shut off when i turn the key off it idles an shuts off after a few i have no turbo timer an i tryed to replace the fuel system relay an it burned it up im clueless on this one an if i press the pedal after the key is off it kills the truck
Old Jan 3, 2013 | 01:21 AM
Bryce's Avatar
Do you have a chip on your truck? Edge juice does have a turbo timer that can be set to turn the truck off after a certain amount of time or after egts cool down below a preset temp but if you tap the pedal it shuts off immediatly. I'm sure other chips also have this feature.
Old Jan 3, 2013 | 12:25 PM
it has an edge on it ill have to play with the turbo timer on it
Old Jan 3, 2013 | 11:05 PM
Ramitt's Avatar
Sounds like its the turbo timer. It has a emergency shut off by hitting the brake pedal.
Old Jan 4, 2013 | 12:11 AM
so how would i go about fixing it mind you this the chip an all was on the truck when i got it so im still learning the ropes with it as far as the chip an timer gos
Old Jan 4, 2013 | 12:43 AM
Bryce's Avatar
On the monitor, press menu then scroll down to juice configuration press enter then scroll down to turbo cool down setup and press enter. From there you can turn it off or change the settings. Keep in mind if you do turn it off, that you should always let the egt cool down before shutting it off especially if you've been running it hard. I would suggest you let it cool down to 350 or less.
Old Jan 4, 2013 | 12:01 PM
smokinoki's Avatar
Default issues
its the key and tumbler mine just did the same thing
Old Jan 4, 2013 | 03:04 PM
ill give it a try an the tumbler ?
Old Jan 4, 2013 | 05:00 PM
Bryce's Avatar
Which edge box do you have? Juice (with or without the attitude monitor), comp, or ez.
Old Jan 9, 2013 | 09:53 PM
attitude monitor got that fixed it was a bad relay again now it says defueling an cuts out on me when i get on it if i take off faster than normal it acts like it skips
