Poor MPG with HX35
Is your cruise boost higher than it used to be? You can use boost to predict MPG just like you can via vacuum (or lack there of) in a gas engine. The more boost you are creating, the lower your MPG will be. Yes a smaller exhaust housing is most likely the dirrect cause.
ya had to be the housing. just not a good setup i suppose. i liked the boos in power over the powerband with the fast spool up but the egt's got crazy quick. And no i did no other fuel upgrades with the swap.
BIG SOCHA
Oct 23, 2014 11:01 PM
